Hello everyone,
I built a micro atx system inside a Fractal Core 1000 with an AMD A10 7850k, but the stock cpu cooler fan is way too loud even when im browsing the web or at the desktop and especially loud during gaming loads. What is a good cpu cooler that is good for minimal overclocking, is low profile, such that it will fit in the matx case and is relatively silent?
Thanks!
- Sic Trix
https://linustechtips.com/topic/177700-fm2-socket-cpu-cooler/
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/177700-fm2-socket-cpu-cooler/#findComment-2384906
Hyper 212+
isnt that alittle high?
https://linustechtips.com/topic/177700-fm2-socket-cpu-cooler/#findComment-2384953
Woops, I guess then the NH-C14
CPU AMD Ryzen 5 3600x | GPU GIGABYTE GTX 1070ti WINDFORCE | MOBO ASUS Prime X570-P | MEMORY XPG Spectrix 2x8GB 3200MHz  | PSU OCZ Zx 850W | CASE NZXT H440
https://linustechtips.com/topic/177700-fm2-socket-cpu-cooler/#findComment-2384977
Yah it is, ive looked at the 212+ and evo and they are both too big for the case.
The nh-c14 does look promising though, however at a higher pricepoint. Thanks for the feedback
its the only low profile cooler i know that is better than the stock
https://linustechtips.com/topic/177700-fm2-socket-cpu-cooler/#findComment-2384985
