2014 Build ....Thoughts..?
Solved by Thomas_the_3rd,
If you're not overclocking, why not go with the 4790?
Seems cool, adding more ssds/hdds will surely help and maybe you should go with a titan for that.
I'm not a specialist but If you're mostly using these programs I think it's good.
**** Update => I ended up going with the 4790 (non K) as well as the Titan black, both of which I received this morning. It took me about two hours to build the system, subject to a bit of cable management, which I have now completed. I'm just running some windows updates, but needless to say this system should be pretty good
Thanks again for the input !!!
