Advice with fans
Go to solution Solved by KamiKatze,
Your temps are fine. Idle temps could be lower but i've seen this kind of bvehaviour with AMD. The stock fan is not bad. You could replace it but it wouldn't improve performance much.
I have a Cooler Master Hyper 212 Evo, which has done a great job cooling my FX-8320, but i have thought of replacing the stock fan. Is it worth it, and which one should i get? I thought of replacing it with a Corsair SP120. Idle temps with stock fan: 40C, gaming: 50C, Prime95 (in-place FFTs): 61C
https://linustechtips.com/topic/177475-advice-with-fans/
