Hello
Recently I've begun streaming CS:Go for kicks and giggles at 1080p/60fps. Internet isn't a problem, as to I have a 40mb/s up, and I had thought my PC wasn't going to be an issue either, but the constantly fluctuating fps between 30 and 210 says otherwise.
Applicable Specs:
CPU: i7 4770k
GPU: GTX 780ti (reference)
RAM: 16gb Dommy Platinums
CPU Cooler: Corsair H100i
Streaming software: OBS
Whenever I'm streaming, my CPU goes to 100% load and gets to ~78-84c. I expected it to reach 100% load but I didn't expect the massive drop in fps. I'm using x264 for video encoding and am streaming at the maximum bitrate that twitch recommends, 3500.
Do I need to upgrade my CPU or am I doing something wrong?
Thanks.
//ccap
https://linustechtips.com/topic/177179-lagging-while-streaming-help/
You really should be using either quicksync or nvidia's nvenc for encoding with OBS.
NVENC guide: http://www.overclock.net/t/1487972/obs-with-nvenc-tutorial-337-50-fix-included
Quicksync guide:
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
