Tropical Air Cooling
Solved by SeanBond,
Any ideas how I can keep things cool without the huge purchases? (60USD is considered a huge purchase from my perspective)
thanks...
Ah my bad, I thought the question was for buiding a cool system. As far as keeping an existing system cool the only real thing you can do is change the location of where the pc sits and how fast your fan speeds are. Something else a little more extreme is buying high quality thermal paste and replacing the existing paste you have on your cpu and gpu but that might not help much.
