Hello LinesTechTips forum!
As I'm building a computer for my friend, 1 thing popped in my mind, as I havn't build SLI builds yet.
His build goes like this
4690k
8gb ram
h100i
Gigabyte gtx 780 ghz edition SLI
gigabyte ga-z79x gaming 5
Corsair 760T
Samsong evo 840 250gb
2TB HDD
Corsair rm850w
So now my thought is. Is 850 a overkill for SLI, or would 750W do the job ?
https://linustechtips.com/topic/176953-will-850w-be-enough/
Go for 850, 750 may do. But you don't want to have to change your PSU in a year when then next gen of GPUs and CPUs comes out.
Next gen is going to be even more power efficient...
https://linustechtips.com/topic/176953-will-850w-be-enough/#findComment-2373589
Bit-tech: With an overclocked 3570k and 780GHz, the system used 420W at most.
HardOCP: WIth an overclocked 3770k and 780GHz, the system used 385W at most, and less than 430W when the GPU was also overclocked.
Eteknix: With a stock 3960X and 780GHz, the system used 430W.
850W could easily do the trick, even while overclocking the CPU and probably GPUs. 750W might be cutting it a little close, but it would probably work.
https://linustechtips.com/topic/176953-will-850w-be-enough/#findComment-2378325
