Hello,
I need help in deciding for the power supply wattage for these parts:
Processor: A10-6800K Mobo: ASUS M5A97 EVO R2.0 RAM: Kingston HyperX FURY 8GB 1866MHz DDR3 CL10 DIMM - Blue (HX318C10F/8) Monitor: ASUS VS228H-P 22-Inch Full-HD 5ms LED-Lit LCD Monitor VideoCard: Onboard (Processor Integrated) SoundCard: Onboard HDD: Western Digital 320 GB 6.0 Gb/s Keyb/Mouse Logitech MK120 Powersupply:?   CPU cooler: Cooler Master Hyper T2
I initially chose Cooler Master Elite Power - 400W Power Supply (RS400-PSARI3-US) but will this be enough?
Thanks!
My system: CPU: Intel i5 6500; Mobo: H110M-k; GPU: Nvidia GT 730; Memory: 16 GB; HDD: 2x 1TB HDD;
https://linustechtips.com/topic/176910-need-help-deciding-wattage/
Well the Asus A88XM-A requires an mATX. But now that you mentioned ITX, I'm going to look for mobos like that.  The case I'm going for is something like Rosewill dual Fans MicroATX FBM-01. The looks of the case isn't really an issue for me as long as it has cable management and good ventilation.
