CPU Bracket squishy double sided tape?
Solved by Enderman,
The double sided tape was there so that you could stick the backplate on the motherboard for convenience while screwing the tower cooler from the other side. It is absolutely not needed and does not offer any additional cooling. If you can manage to hold the backplate in place with one hand, while counting the cooler with the other, you will be fine without any tape.
errorcode123_dindin1 ·
Posted in General Discussion2 -
Packhunter ·
Posted in Graphics Cards1 -
11
2
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies3 -
Airmack ·
Kyle89 ·
Posted in Troubleshooting2 -
8
5
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
