Hello, I recently bought parts for and built a gaming PC. I bought an EVGA Geforce GTX760 graphics card and for the past week my computer has been working fine. But today my computer crashed and after restarting it, my monitor wouldn't receive any signal. To ensure that it wasn't the monitor or the cord I plugged the monitor into my motherboard and I receive a signal. After further inspection I found out that my computer doesn't even sense that the graphics card is a part of it. I took the card out and put it back in, making sure that it was put in securely and correctly. i have no idea what the problem is. The card is getting power, as I have plugged in all power ports for it, and I have not overclocked it, so if anyone could help me and tell me what the problem is i would greatly appreciate it.
Computer specs:
GeForce GTX 760 Graphics card
Asrock B85 motherboard
Cosair CX600 power supply
8 GB Ram
1 TB Hard drive
(And incase it matters, my computer is running Windows 8)
https://linustechtips.com/topic/175248-need-help-with-graphics-card/
Computer specs:
8 GB Ram
1 TB Hard drive
You have all the power connectors connected to the gpu correct? And what type of cable are you using to connect the monitor to the gpu?
Gaming rig- Cpu- Amd 9590, 16gbs of G Skill Ram, Gpu- GTX 760 windforce 3 edition 2gb. A Thermaltake water 2.0 water cooler for my cpu. Keyboard- Thermaltake Posieden , Case- 750D, Mobo Asus 990fx R2.0. 24 inch Dell LED monitor
i would say your gpu fried or something, and its evga they have the best rma around
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
Yes all power connectors are connected to the GPU and I am using a VGA cord since my monitor does not have HDMI
Hmmmmm. If your computer worked fine before today and you haven't touched it... Actually its entirely possible its your psu (I think), I have the same exact psu as you and the first time I bought it after my computer ran for 20ish minutes the computer blue screen and it wouldn't boot. But I don't think it was powering anything after that. So if you have a friend who has a discrete gpu I would try using theirs in your pc first... If not you should RMA the 760.
Computer specs:
8 GB Ram
1 TB Hard drive
Actually try resetting the BIOS to factory default first then see if it works by any chance.
Can you try the gpu in an another machine, just to see if it works there?
Because that would eliminate a faulty gpu.
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
@sloop, pretty sure having a video in your sig is against the rules seeing as it's not supposed to be over 4 lines long.
Pretty annoying on mobile device.
Well ill change it but you didn't have to call me out on a question. Just PM me or something if you're that bothered by it.
Give your meat a good old rub
