TV Setup Help
Solved by TheSLSAMG,
It uses an HDMI passthrough, so you plug the cable box/Chromecast into it, and plug the bar into the television's HDMI port. Or, you can use an optical audio cable from the bar to your cable box.
Pages 12 and 13 contain relevant information. http://downloadcenter.samsung.com/content/UM/201303/20130304123559265/02644D-00_F450_ZA_130227_New_Remocon.pdf
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
