Ok, so im making an itx PC to take to lans ect
My current choices in parts are as follows:
Motherboard: ASUS P8Z77-I Deluxe Mini ITX
CPU: Intel i5 3570k
SSD(s):??????
Case: Bitfenix Prodigy black
Cooling: Corsair H100i
GPU: Sapphire Radeon HD7970 3gb OC
Memory: Corsair dominator platinum 16gb (2x8) 1866mhz
Monitor (for at home, i most likely wont be playing games with it):???????
PSU: Corsair CX750 V3
What would be appropriate parts for the SSD and monitor that are relatively inexpensive and fast.  Also, if you have any ideas of how I could price cut that would be extremely helpful to. I have a lot of trust in the dominator ram however i do realize how pricey it is. If anyone could mention reliable but cheaper 16 gig (2x8) that would be good. Anything to cut price but keep gaming performance and quick boot times would be great.  Also, id like to have 2 SSDs (maybe in raid) and i was wondering where i could stick the second one in a bitfenix prodigy (after all the HDD cages have been taken out). I am fully open to ideas.  If i end up changing the whole build, thats fine by me as i want the best lan rig i can get for around the budget of this build. Also, is it worth my while water cooling later on when i get the funds??
Thanks
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/
It doesn't really matter what SSD you pick unless you need some of that enterprise stuff.
What worries me about your build is your cheapo psu.
You only need something like a 500W psu for all of that. Seasonic makes a gold rated 550w that's modular for 10 bucks less, I think.
I'm just going to leave this here.....
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-200831
I'd get ANY cheaper 1600 ram. The samsung 840/pro is a good ssd.
The psu could be lowered to 500w but 600w is better for headroom and better psu temps.
The 7950 is a better bang for your buck.
The motherboard is overkill and I think a cheaper one with wireless lan/bluetooth wouldn't be too hard to find.
What size of a monitor are you thinking of? Multiple monitors maybe?
Mostly importantly, what's your budget?
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-200851
Im thinking of a 21-24inch maybe, probably around 200,250 dollars
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-200892
CPU: Intel i5 3570k
SSD(s):??????
Thanks
Moved to NB&P
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-200898
$200 is a bit much to be spending on a monitor that size. I was hoping you could tell me your overall budget for all the parts.
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-200913
Yeah, well i was thinking of spending 1.5k on the build, maybe a bit more 1.8k or something, i am running a budget as i dont want to waste money on it like i did my home rig. Also, i have 3 titans in my home rig, could i take one of them out and put it in the betfenix as im never going to use it in the near future.
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-203963
Omagerd, totally do so. 3 titans is overkill.
Try something like this with the titan: http://gyazo.com/d007fb4ba361509c0b4c3779206c20cf
Slap that inside your case^^^
I'd get a bigger monitor like this. : http://www.newegg.com/Product/Product.aspx?Item=N82E16824236103
The titan shouldn't have to push a single 23". It would be a bit sad.
1.5k is a bit much for me for a prodigy build if you already have a titan you can use. 1.2k is a better sweet spot for me on a build like this.
Personally, I'd get something like 12tb of storage in a full/mid atx tower with 1.5k.
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-204074
Thanks, helped a lot, im not very good with small PCs so I really had no idea
https://linustechtips.com/topic/17428-building-a-mini-itx-pc/#findComment-205447
