Here you go
PCPartPicker part list: http://pcpartpicker.com/p/P9Y3mG
Price breakdown by merchant: http://pcpartpicker.com/p/P9Y3mG/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($339.99 @ Newegg)
CPU Cooler: be quiet! Dark Rock 3 113.8 CFM Fluid Dynamic Bearing CPU Cooler  ($59.99 @ NCIX US)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Memory: Team Vulcan 16GB (2 x 8GB) DDR3-1600 Memory  ($134.99 @ Newegg)
Storage: Sandisk Ultra Plus 256GB 2.5" Solid State Drive  ($104.99 @ Amazon)
Storage: Western Digital Red 3TB 3.5" 5400RPM Internal Hard Drive  ($119.99 @ NCIX US)
Video Card: MSI Radeon R9 290 4GB TWIN FROZR Video Card  ($409.99 @ Micro Center)
Case: NZXT H440 (Red/Black) ATX Mid Tower Case  ($119.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($86.66 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Monitor: Acer K272HULbmiidp 60Hz 27.0" Monitor  ($398.77 @ Amazon)
Total: $1995.33
https://linustechtips.com/topic/174263-need-feedback-on-a-build/#findComment-2314557
What are you going to do with this system?
You should get the i7 4790k it's only a couple bucks more and it overclocks much better.
If this is a gaming build, then you should think again many of the choices on the partlist.
I don't understand why you picked that PSU, go with something like the EVGA Supernova 750 G2 or the XFX Pro 750W they are much better units.
Thats a lot of noctua, if you want it for the noctua goodness then It's fine, but if you want decent cooling and quiet operation; Rosewill Hyperboreas, Be Quiet! Pure Wings 2, Cougar Vortex or Artic F12 will be a cheaper option that is going to quietly do the job well.
https://linustechtips.com/topic/174263-need-feedback-on-a-build/#findComment-2314574
Better: http://pcpartpicker.com/p/HvHXYJ
thanks guys, this is my first build so i'm kind of new to this and yes this will be a gaming pc
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/174263-need-feedback-on-a-build/#findComment-2316316
