so i got my msi gtx 760 hawk today, so i installed al drivers etc, then i looked at the core speeds, and its 980mhz default and under load it went to 1085mhz, but shouldn't it be 1111mhz base clock? and a boost to 1176?
and i tried to download the msi gaming app but that didn't work either '':msi gaming app the platform doesn't support this application'' this is with version:msi gaming app 1.0.0.13
i can't find any older versions like 1.0.0.3 or .5  so if anyone can tell me how my core clocks are lower then they should be and why the msi app isn't working i would appreciate it!
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/174261-msi-gtx-760-hawk-help/
Try a bit of voltage offsets on MSI afterburner  :rolleyes: ?
Follow yer topic
not doing anything,
i'm trying evga x now
https://linustechtips.com/topic/174261-msi-gtx-760-hawk-help/#findComment-2314558
Try using a voltage offset of 25mV or something
i cant give it more then 12mV in msi afterb, but with 12mV it went to 1097 under laod tho,
https://linustechtips.com/topic/174261-msi-gtx-760-hawk-help/#findComment-2314572
Try using EVGA Precision x then, I don't use MSI afterburner myself aswell
evga made it even wurse, now it won't go higher then 540mhz..
maby i should try to ovc it my self and see how high it goes, idk tho
https://linustechtips.com/topic/174261-msi-gtx-760-hawk-help/#findComment-2314597
540MHz ? I think you're not even testing it, did you benchmark after it? 540 MHz is probably idle
if evga is running, and i'm stressing the card, it wil not go highe then 540, but with msi afterburner it goes around 1080 underload.
https://linustechtips.com/topic/174261-msi-gtx-760-hawk-help/#findComment-2314622
That is strange... I'm getting the same results on MSI afterburner as on Precision X, meh I don't know then.
it's oke, thanks for the help anyway, i will post again if i found the problem
https://linustechtips.com/topic/174261-msi-gtx-760-hawk-help/#findComment-2314640
@Wano1997 problem solved,
i turned of the pc switches between the bios on the card, installed the drivers on the STD bios of the card, now its running 1111, and under load it even went past it's boost clock of 1176 to 1215!
https://linustechtips.com/topic/174261-msi-gtx-760-hawk-help/#findComment-2314765
