Razer Kraken Pros Sound
Halbo
I have recently purchased a Razer Kraken Pro Headset, it has had perfect sound until now. I tried activating its surround sound and it has made everything sound like trash especially in games. Please Help!!!!!!
Razer stuff is bad. I have the same thing. Been more than 5 months still hurts my ears. I got no tips.
I think i might try uninstalling Razer Synapse and Surround and see if it helps
The surround sound is never any good, I'd recommend returning it if you can and getting headphones + clipon mic or antlion modmic. Also Razer stuff is usually just bad so just avoid them in general.
Just uninstall the surround sound software. I used it on my Kraken Pro's in the past with no problems.
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
I tried using their surround sound once, and it made everything impossible to hear and just terrible unless I was the the perfect angle. If you want surround get a headset that comes with it.
