well i have been planning out a build for some time and i got around to ordering a few components, but what i mostly had trouble selecting was the WC components since its my first time, ofc people on the forum have helped me alot with the selection but i want to make sure that my choices specially of the WC components is correct, and that i haven't got something that won't fit either the fittings or tubing.
Components:
MB: Asus Rampage IV Black Edition (delivered)
Cpu: I7 4930K
Gpu: GTX 780 ti sc
Case: Corsair 760T (delivered)
Storage SSD: Samsung Evo 840 pro 512GB
Storage HDD: WD Blue 2TB x2
PSU: Corsair AX 860i
WC:
Cpu Block: Ek-Supremacy Clean Csq - Acetal + Nickel (delivered)
Gpu Block: EK FC780 GTX Ti Full Cover Nickel Acetal (delivered)
Gpu Backplate: EK FC780 GTX TI Backplate - black (delivered)
Pump: EK-D5 Vario X-TOP - Acetal
Tubing: Monsoon 1/2" OD Hardline Tube - 4x 24" Pack - White
Fittings: Monsoon Free Center Hardline Compression Fittings , 3/8" x 1/2" 6-Pack - White
I Listen. i Observe. I Learn. I make my own decision
https://linustechtips.com/topic/173625-will-my-wc-setup-work/
Why are you using a 780ti waterblock on your CPU....?
https://linustechtips.com/topic/173625-will-my-wc-setup-work/#findComment-2305982
