This is my build
Fx-8350 4.0 maybe in the future till 4.2 with a cooler master T4 with 2xfans
Sapphire r9 280x 3gb
Here is the problem
Fx-8350=http://www.bit-tech.net/hardware/2012/11/06/amd-fx-8350-review/7
r9 280x=http://www.bit-tech.net/hardware/graphics/2013/10/08/amd-280x-270x-260x-reviews/9
Because it consumes around 563 watts but not sure if i should buy the Corsair cx600w 80+ bronze
https://linustechtips.com/topic/173450-help-with-psu/
Hmm 600w seems to be a skim of the edge, 650w is better and will last an upgrade or two
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/173450-help-with-psu/#findComment-2303952
This is my build
Here is the problem
600 is pushing it abit, get a 650
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/173450-help-with-psu/#findComment-2304023
600W would be more than enough, but I wouldn't go with a CX600. Not really a good PSU. XFX Core Edition Pro 650W, Cooler Master V650, or Rosewill Capstone-650-M. These are the best PSU's for the money.
https://linustechtips.com/topic/173450-help-with-psu/#findComment-2304400
Neither is pushing it. You'd be hard pressed to draw more than 500w outside of synthetic benchmarks.
Where'd you get 563w?
https://linustechtips.com/topic/173450-help-with-psu/#findComment-2305342
