Nvidia 670 dual monitor help
Hades
Ok so im trying to connect ny monitor and tv with my single gtx 670, im using the dvi-d for the monitor and hdmi for the tv.
The problem that im getting is that my tv is blacked out with no signal. When i use dvi to vga for the tv i get signal.
Im woundeeing if this is because the gtx 670 is limited to a single Digital signal at a time. Only possible configurations for this board is:
DVI-D + VGA
or
HDMI
Thanks for the help and time
Doubtful. I have a GTX 680 and hooked up two screens via DVI and a TV via HDMI.
What if you just connect the TV via HDMI? It might just be the cable.
It 1am here will try tomorrow and tell u
I did try the hdmi with the monitor and got no signal could it be the cable?
check what your TVs input is set too.
Very noobish answer LOL!
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
Yeah it could be the cable. Try hooking up just the TV with the HDMI cable and see what happens. Got a spare cable you can use?
It's such a basic, silly thing. That might actually be the solution LOL
That stuff really happens often enough.
Ok still having problems
Update:
I know the hdmi cable works as ive tested it with the tv
When i connect it to my pc to monitor it doesnt work but if i use dvi or vga i get a signal
The hdmi wont give a signal on the tv and monitor
did you mail nvida/other manufactors (or the shop you got it from) about this problem?
right click on desktop --> screen resolution --> multiple displays dropdown box --> extend these displays
You've probably tried this but just making sure.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
Ive tried that the problem lie with the Hdmi it wont give any signal on any display.
All other output display work
