CPU: Intel i7 4790k
GPU: Sapphire R9 290 4GB TRI-X OC
MOBO: MSI Z97 GAMING 5
Case: NZXT PHANTOM-BK
PSU: SeaSonic X Series X-850
RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB)
SSD: Samsung SSD 840 EVO 250GB
HDD: WD Green 3TB
CPU Cooler: Noctua NH-D14
Monitor: LG 27EA33V-B
Aim: Mostly Gaming,A little Video editing and Graphics Design.
Budget: If possible,i'd like changes for a $2500 Build(Mouse,Monitor and Keyboard included)
I don't really know if this is a good build,So any changes,recommendations/suggestion is very helpful.
https://linustechtips.com/topic/173246-my-buildneed-help/
Seems solid, switch the HDD to something like a Seagate baracuda or a WD Black. The greens are nice but I feel you lose some quality test info on it.
Main Rig: White Lightning  = -Intel Core i7 3770 (4.1Ghz)-Zalman CNPS12X-MSI Z77A-G45-16GB G2 Patriot-MSI GTX 660TI OC PE-Corsair 650W-Corsair 600t White-
Laptop: MSI GT60 = -Intel Core i7 4700MQ-MSI GTX 770M-
Peripherals: Corsair K90-Corsair M90- Corsair 2100-CM Storm Quickfire TK (Green Switch)-Logitech G700
https://linustechtips.com/topic/173246-my-buildneed-help/#findComment-2301702
  • 3 weeks later...
Hi damieny, awesome looking PC specifications you have there. Therefore, I would like to give you my part of suggestion in terms of the HDD selection. For your current build which is made for gaming and performance, I suggest you to go for the Western Digital Black Hard Drive instead of the Western Digital Green Hard Drive. The solid reason for this particular recommendation is just that the WD Green is made for primary use and also as an secondary storage due to its power saving technology. Hence, the WD Black is created for gaming users and also to ensure maximum performance of the machine, which I believe is the most ideal choice for your current build as well. For broad information of the WD Black, kindly visit the below link:
Hope the above suggestion fills the gap at your end.  :)
https://linustechtips.com/topic/173246-my-buildneed-help/#findComment-2443461
