I recorded a clip of some gameplay today. I re watched the clip to make sure it was okay and I heard white noise in the background which is weird. I just got this new headset which is the corsair 2100 vengeance and I thought I make commentaries. I have the drivers btw. I tried contacting corsair and got no response. Does anyone have a clue to stop this noise? It goes away when I mute the mic, but then comes back when I unmute it.
Here is video example https://www.youtube.com/watch?v=y4yNKHuaGwY
The beginning is with the mic on and then I mute it near the end.
https://linustechtips.com/topic/173142-white-noise-recording/
Without the video it's hard, but what you are describing is usually just a noisy gain stage in what ever device the mic is plugged into.
EDIT: yep, just noise from the preamp, are you using onboard or is the headset usb?
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/173142-white-noise-recording/#findComment-2300365
Sounds like you mean background noise? Most mics pick it up. You can edit it out afterwards and minimize it by adjusting recording settings. No one can watch your video btw.
I fixed it, so you can watch it now. Also it only picks on up the two noises that are happening my clicking for my mouse and typing. Otherwise nothing else is going on in my room.
https://linustechtips.com/topic/173142-white-noise-recording/#findComment-2300369
The video should work now. The mic is plugged into my motherboard usb 3.0 slot.
see edit in my post above.
https://linustechtips.com/topic/173142-white-noise-recording/#findComment-2300376
You should be able to reduce the noise by turning down the gain in your sound manager for the mic input and talking louder.
https://linustechtips.com/topic/173142-white-noise-recording/#findComment-2300404
Plug it in to the back of the computer directly into the motherboard not in the front panel. Front panel tends to create interference.
CPU: i7 4770k CPU Cooler: Corsair H100i Mobo: Gigabyte z87 ud3h Memory: 16GB Corsair Veng. 1866MHz  GPU: EVGA SC 780 PSU: Corsair ax850 Case: Define R4 BlackOut Edition SSD: Samsung 840 EVO HDD: Two WD Black 7200RPM 1TB
https://linustechtips.com/topic/173142-white-noise-recording/#findComment-2300426
I don't help pirates.  ;)
how do you know he's a pirate?
@immrthomas
Apply a low pass filter (6Khz and above with about a 3db roll off) is about the best you can do, it won't take it all out but it will take the most noticeable hiss.
https://linustechtips.com/topic/173142-white-noise-recording/#findComment-2300464
okay thank you :D
Edited my post, I meant low pass filter, that could have been interesting, take out all the vocals and leave the hiss. :blink:
https://linustechtips.com/topic/173142-white-noise-recording/#findComment-2300639
