[PCPartPicker part list](http://uk.pcpartpicker.com/p/w9MWBm) / [Price breakdown by merchant](http://uk.pcpartpicker.com/p/w9MWBm/by_merchant/)
Type|Item|Price
**CPU** | [intel Core i5-4670K 3.4GHz Quad-Core Processor](http://uk.pcpartpicker.com/part/intel-cpu-bx80646i54670k) | £155.94 @ Aria PC
**Motherboard** | [MSI Z97 PC MATE ATX LGA1150 Motherboard](http://uk.pcpartpicker.com/part/msi-motherboard-z97pcmate) | £69.54 @ Aria PC
**Memory** | [Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory](http://uk.pcpartpicker.com/part/kingston-memory-khx16c9b1bk28) | £58.18 @ Amazon UK
**Storage** | [seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive](http://uk.pcpartpicker.com/part/seagate-internal-hard-drive-st2000dm001) | £52.79 @ Aria PC
**Video Card** | [MSI GeForce GTX 760 2GB TWIN FROZR Video Card](http://uk.pcpartpicker.com/part/msi-video-card-n760tf2gd5oc) | £169.75 @ Scan.co.uk
**Case** | [Corsair 300R ATX Mid Tower Case](http://uk.pcpartpicker.com/part/corsair-case-300r) | £59.16 @ Scan.co.uk
**Power Supply** | [Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply](http://uk.pcpartpicker.com/part/corsair-power-supply-cx600m) | £49.93 @ CCL Computers
**Other**| screen| £131.65
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | £746.94
[PCPartPicker part list](http://uk.pcpartpicker.com/p/ggF3mG) / [Price breakdown by merchant](http://uk.pcpartpicker.com/p/ggF3mG/by_merchant/)
Type|Item|Price
**CPU** | [AMD FX-8320 3.5GHz 8-Core Processor](http://uk.pcpartpicker.com/part/amd-cpu-fd8320frhkbox) | £100.79 @ Aria PC
**CPU Cooler** | [be quiet! Dark Rock 3 113.8 CFM Fluid Dynamic Bearing CPU Cooler](http://uk.pcpartpicker.com/part/be-quiet-cpu-cooler-bk018) | £49.42 @ Scan.co.uk
**Motherboard** | [Gigabyte GA-990XA-UD3 ATX AM3+ Motherboard](http://uk.pcpartpicker.com/part/gigabyte-motherboard-ga990xaud3) | £74.80 @ CCL Computers
**Video Card** | [XFX Radeon R9 280 3GB Black Edition Double Dissipation Video Card](http://uk.pcpartpicker.com/part/xfx-video-card-r9280atdbd) | £179.14 @ Scan.co.uk
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | £755.86
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
https://linustechtips.com/topic/172454-between-two-builds/
Type|Item|Price
 | | **Total**
Intel allday erhyday.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2292246
Type|Item|Price
 | | **Total**
Got the best CPU,
The other got a cpu coolor that can be nice if you hate a loud computer
CPU: Intel Core i5-4670K Cooler: Noctua NH-D15 Motherboard: Gigabyte GA-Z97X-UD3H-BK RAM: Kingston Beast 8GB (2 x 4GB) SSD: Samsung 840 EVO 120GB HHD Western Digital Caviar Blue 1TB GPU Asus GeForce GTX 770 2GB CASE: Fractal Design Define R4 PSU: Corsair RM 550W OS: Windows 8.1 Wireless network: Asus pce-n53 (Broken)
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2292263
I suggest this build:
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£155.94 @ Aria PC)
Motherboard: MSI H97 GAMING 3 ATX LGA1150 Motherboard  (£85.02 @ CCL Computers)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory  (£54.69 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£74.40 @ Aria PC)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  (£200.59 @ Aria PC)
Power Supply: be quiet! 600W 80+ Bronze Certified ATX Power Supply  (£58.32 @ Scan.co.uk)
Total: £743.91
Overclocking can already be done on H97 asus boards, so it should be available on MSI boards soon.
I chose the MSI over the top H97 asus board because it has better sound and just overall better quality and looks.
There is also a 256GB SSD :)
280X instead of 280/760, so you are essentially getting gtx 770 performance with more VRAM, so it will last longer (in terms of performance and maxing out games)
Feel free to ask any questions
Samung Tab S 8.4
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2292272
Total: £743.91
would for costs saving a 120GB be good enough for OS only? or it will be not good enough?
My PC:
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2294242
You yourself suggested 2 builds which are more expensive than this one. Games are becoming bigger so i suggest you stick with the 256GB variant.
Samung Tab S 8.4
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2295035
My build also has a monitor and i want to fit all that in a budget of around 700-800 pounds
My PC:
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2296654
Oh right, i'll adjust mine accordingly.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£120.00 @ Amazon UK)
Motherboard: MSI H97 GAMING 3 ATX LGA1150 Motherboard  (£83.96 @ Scan.co.uk)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card  (£158.99 @ Aria PC)
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  (£102.24 @ Amazon UK)
Total: £743.30
OR
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  (£44.94 @ CCL Computers)
Total: £755.44
Samung Tab S 8.4
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2297190
Total: £755.44
I could spend 20 more pounds and get the 4670k  and get a cooler later
My PC:
https://linustechtips.com/topic/172454-between-two-builds/#findComment-2298460
