need help with decisions
Go to solution Solved by ohJey,
if you upgrade Cpu and mobo then you'll have to upgrade ram
heloo,
i have a asus p5kpl-am/ps and an intel core two duo E7600 with 4gb of ddr2 (dont judge)  should i uprade cpu+mobo or ram?
Judging by the hardware you have, if your going to upgrade I recommend just building a completely new system.
Gaming rig- Cpu- Amd 9590, 16gbs of G Skill Ram, Gpu- GTX 760 windforce 3 edition 2gb. A Thermaltake water 2.0 water cooler for my cpu. Keyboard- Thermaltake Posieden , Case- 750D, Mobo Asus 990fx R2.0. 24 inch Dell LED monitor
https://linustechtips.com/topic/172293-need-help-with-decisions/#findComment-2289827
