What kind of dollars are you using?
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2279198
Sorry it is in US dollars. I was considering a different cooler that would be as good and about the same price as the hyper since I have tall ram but I can move the fan or raise it up so shouldn't cause an issue with the ram.
Source 210 Windowed: http://pcpartpicker.com/part/nzxt-case-cas21w2b1
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2279354
Corsair SPEC-01? I don't know if this is a good case or not.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2280743
I like the way this one looks, the NZXT one looks a bit ugly/plain to me. I know the SPEC-02 size wouldn't allow for the hyper 212 evo. No idea about this one.
EDIT: According to Corsair the Spec-01 supports coolers up to 150mm. I believe the hyper 212 evo is 149mm tall. So yeah that would be cutting it way to close.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2280751
There's these: Zalman Z5, Z11 Plus, Z12 Plus, and the Inwin GT1, along with the rest of these on the PCPartPicker list.
Z5.
8GH9_8849BABD-D393-429A-8699-B14C152FBF6
Z11 Plus.
Z12 Plus.
Inwin GT1.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2280821
The 212 Evo is 159mm tall and not 149.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2285588
Ah, for some reason I was thinking of 149 I guess.
How acurate is pcpartpicker's compatibility? Atleast for case and CPU Cooler?
Also I have an old HP case, I was thinking of putting my stuff in it, until I can get a better case and leave the side off because I doubt there would be good airflow in it due to not having any case fans in it. What do you think? Also would be using the stock HS/Cooler until I can get a better CPU cooler too.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2288082
Pcparpicker is pretty accurate for cpu cooler clearance.
What parts are you planning to place inside?
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2288146
What parts are you planning to place insidr?
It is going to contain xfx 650pro psu Asus r9-280 directcui gigabyte z97sli board(supports crossfire too) DVD writer i5-4670k 1tb wd blue hard drive. Will also contain the hyper 212 evo. I have everything needed except a good case and a good after market cooler. Sorry on a cell phone so harder to type. Currently don't have a monitor but planned to use my tv atm.
http://pcpartpicker.com/p/tQfzFT that is my build. I already bought AS Ceramique 2 TIM.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2288426
The Source 210 would be fine for that but I wouldn't recommend sticking with an old HP case. Are you planning a new build and is everything not purchased yet?
The aftermarket paste is unnecessary. Keep it for future builds--the 212 Evo comes with good paste.
Just wish I would have thought about the height of my ram.
It's fine. If it's too tall, you can just move the fan to the other side of the heatsink.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2310755
I have everything except a good case. I wanted to test it out and see how well it worked and see if I had any DOA items too.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2312464
It would be nice to test it, though a little afraid of something happening. Also seems replacing the cpu cooler with a different one could be risky, and a little difficult to remove the heatsink from CPU.
https://linustechtips.com/topic/171542-case-recommendation/#findComment-2315857
