i have recently been messing around with the settings in the bios and changing voltages, clock speeds and cache ratios + more. I have also disabled turbo so my 4770k only runs at 3.5ghz and when i play games like bf4 my cpu temps go up to anywhere from 59-64 C and i idle on 34C this seems really bad for an under clocked 4770k??
I have an asus z87 board an i am wondering if there is a way in the bios to reset all of the "AI Tweakers" that i have done for the ram and processor. However i am hesitant to click the reset to default button incase it resets "RAID's" and/or deletes all of my storage on my PC or if it deletes windows. all i want to do is get get my processor and ram back to stock.
 My PC: CPU: i7 4770K @ 4.2 Ghz MoBo: ASUS Z97-ATX SLI RAM: 8GB (2x4) 2400Mhz GPU: Palit Jetstream 780 TI Memory:1TB Seagate + 120Gb Kingston SSD  PSU: Corsair RM 850W Gold Monitor iiyama 27" 144hz Monitor CPU Cooler Corsair H100i
https://linustechtips.com/topic/171444-4770k-help/
 Did you enable RAID for the SATA if so then your kinda screwed  otherwise go into the BIOS and just reset the BIOS
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/171444-4770k-help/#findComment-2278054
i hvae just "reset to oprtimized" defualts and sucssefullt booted to windows. my cpu is so bad that 3.9 ghz requires 1.200v!!
https://linustechtips.com/topic/171444-4770k-help/#findComment-2278065
No thats not bad thats stock voltage you can hit 4.3Ghz with that voltage easily.
|King Of The Lost|
https://linustechtips.com/topic/171444-4770k-help/#findComment-2278071
