Do I need a wireless card?
Solved by WoodenMarker,
yes
Then unless you have a motherboard with wireless connectivity, yes--you would need a wireless card for WiFi.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Get a USB receiver they are cheaper than a internal card and a lot easier to use since you wont have to deal with stupid third part software
They're usually fat and take up slightly more than one usb port though.
then what would I get and how would I use it.
Get one and plug it it. It may or may not need manual driver installation.
