Java Regex Help
Go to solution Solved by wolfsinner,
The following pattern should capture what you need: \\d{1,2}[A-Za-z]{3}
EDIT:
I failed to realize you probably also want some code to go with that. :P
The following code is untested, but gives you the general idea.
String pattern = "(\\d{1,2}[A-Za-z]{3})";Pattern p = Pattern.compile(pattern);Matcher m = p.matcher(htmlStr);if(m.find()){         for(int i = 1 ; i <= m.groupCount() ; i++){                  //treat m.group(i)         }}
So I'm doing this program that requires me to extract strings from a HTML page.
I'm very new to regexs and was wondering if there was a way to find:
1 or 2 digit integers and 3 chars.
eg: 8SCK or 10SCA
It also has to be able to avoid picking up something like this: BAABA
Thanks.
3700x, Asus B450i, 16GB Corsair Vengeance RGB, Gigabyte GTX 970 ITXDan A4-SFX, SX600-G, 120mm AIO.
https://linustechtips.com/topic/171067-java-regex-help/
EDIT:
Want to solve problems? Check this out.
https://linustechtips.com/topic/171067-java-regex-help/#findComment-2273307
