So I decided to go with a raid 0 ssd for my pc, however, I ran into this problem.
After I set up my raid 0 (after I enable it via bios) and continue on with win 7 instalation I run into this problem "Windows setup could not configure windows to run on this computer's hardware"
Any idea how to f ix this issue?
Edit: just posting the steps I take.
Connect my SSDs to mobo (I dont disconnect them, just saying where I started)
while pc starts up mash furiously del key
enter bios>advanced bios
go to sata configuration
select raid mode
pc reboots
I press ctrl+i to enter raid config
rename volume0 to Raid 0
choose raid  (striping)
choose that 128kb
size 223.6
create raid volume
pc reboots and enter win 7 instalation
I select disc 0 (the only one with data available, btw no other disc is present)
win 7 completes instalation and reboots
it stays on "completing instalation"
then I get that "Windows setup could not configure windows to run on this computer's hardware"
Another update: I can install win 7x64 ultimate on my SSD (non raid)
FIXED: I downloaded Intel® Rapid Storage Technology Driver Software and installed during os instalation (just click on drivers OS will look through your usb drive and pick what it can use)
https://linustechtips.com/topic/170276-win-7-has-problems-with-my-raid-0/
