Help picking a Macbook
Less than £1000 and using for school, internet browsing, light video editing
With that budget, you can only afford the less powerfull Macbook pro, it should serve all your needs tough. I would need input from other people to know if 4GB of ram is enough for light video editing but you can always upgrade it later in the Macbook Pro. http://store.apple.com/uk/buy-mac/macbook-pro?product=MD101B/A&step=config
An other choice is a Macbook Air, you can't upgrade it and it's going to have less (a lot less) storage because it uses an SSD but if you can store most things on your existing desktop having that fast storage is really nice.
http://store.apple.com/uk/buy-mac/macbook-air
Your choice for the size of display and memory but I wouldn't choose only 128Gb, I think it's not enough.
