Volume is lowering itself automatically
Go to solution Solved by Altecice,
Right click the Speaker on your notification area and select "playback devices" go to the tab that says "communications" and make sure *Do nothing* is selected.
So I've got these speakers and I don't know if it's the speakers or windows lowering the volume but it will randomly lower the volume for no reason at all. It started again today and it hasn't done it in about a week. It happens with any program (iTunes, Twitch, etc..) If anyone can help me I'd really like it! Thanks for the help.
https://linustechtips.com/topic/170168-volume-is-lowering-itself-automatically/
It's probably the volume knob on the speakers. Try turning it from min to max a couple of times
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
Hopefully this works!
Not it. It lowers the volume in the Speakers are and it's lowered but it shows two arrows one at the original volume and one lowered.
Try this ???
OR
Re-install drivers
CPU: AMD 5790t Motherboard: Gigabyte Forumlar XII RAM: Ah Whole set of it GPU: GTX 290x Ti Storage: Ah Ton of HDD PSU: Once it on Display(s): Well I still seeing pixels Cooling: It running COOL BRO Keyboard: *click* *click* Mouse: MORE *click* Sound: OHH DE BASEE
AWW YEAAA!!!!
