RM650 would be more than enough, RM750 if you want to go SLI in the future.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/170072-new-build-need-help/#findComment-2260478
you need to be more specific than that, also what are you planning to do with it? what games do you run?
what is your total budget?
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/170072-new-build-need-help/#findComment-2260479
You would't need a i7 for gaming. Go ahead for the I5 and use the money you saved on a SSD or something.
I would go for this;
CPU - I5-4690k
CPU cooler - Either a h100i if you want a lot of cooling, or you can stick with a Airflow from Noctua.
Mobo - Asus z97 mobo
GPU - gigabyte gtx 780
PSU - Any 650W (your choice)
RAM - 8GB ram of either corsair or kingston. You dont need more than 1866 mhz.
SSD - Samsong Evo 840 120 GB
HDD - any place from 1-4TB, what suits you best
Case - Up to you personally. but you need atleast a midtower if you want a h100i, unless you want a tidy build.
https://linustechtips.com/topic/170072-new-build-need-help/#findComment-2260549
CPU - I5-4690k
https://linustechtips.com/topic/170072-new-build-need-help/#findComment-2265826
