Need help on my PC
Solved by Wano97,
Just to make sure this will support 2 gtx 780 ti(s) in sli correct? And one last question, is it 2 gtx 780 ti(s) or is it 2 gtx 780 ti? Its been bugging me like crazy!
It's one Gtx 780ti, or 2 Gtx 780ti's. And The corsair obsidian? Yes it will EASILY fit 2 780ti's, much better than a fractal design r4
It also supports 3 Gtx 780ti's, I don't know about 4
FancyPants101 ·
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
