Above 60 at low settings
At 4k? Or 1080p?
He has a 1080p monitor in there, so I'd assume the OP is referring to 1080p.
You should expect more than 60fps on Ultra in about any game you throw at it. The 280x is usually the card to goto for 1080p, so the 290x will be more than capable of handling any games you throw at it.
//ccap
https://linustechtips.com/topic/168091-first-pc-build/#findComment-2236043
http://pcpartpicker.com/p/24QMTW I will be using this PC to play games. What's FPS should I be looking at.
That's a very broad question... just google "r9 290x benchmark 1080p" and look for the game you play.
Anyway, if you dont buy this computer yet, I think we can easily make a better one for you. And why would you need 2 CD driver for anyway?
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/168091-first-pc-build/#findComment-2236044
That's a very broad question... just google "r9 290x benchmark 1080p" and look for the game you play.Anyway, if you dont buy this computer yet, I think we can easily make a better one for you. And why would you need 2 CD driver for anyway?
I didn't mean to get two optical drives
https://linustechtips.com/topic/168091-first-pc-build/#findComment-2236052
Could you suggest me a better build?
https://linustechtips.com/topic/168091-first-pc-build/#findComment-2236060
Well... what will you use this for? just gaming or alot of video rendering, 3D modeling etc as well?
Assume that you are just going to game and do normal stuff that's not heavy rending/modeling, then this
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($239.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($139.99 @ SuperBiiz)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory ($173.98 @ Newegg)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive ($104.99 @ Micro Center)
Storage: Western Digital AV-GP 2TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Newegg)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card ($469.99 @ Micro Center)
Case: Corsair 450D ATX Mid Tower Case ($114.39 @ Mwave)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($109.00 @ Amazon)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($14.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Monitor: Asus VE278H 27.0" Monitor ($214.99 @ Newegg)
Keyboard: Corsair Vengeance K95 Wired Gaming Keyboard ($129.99 @ Amazon)
Mouse: Corsair Raptor M45 Wired Optical Mouse ($49.99 @ Newegg)
Total: $1972.24
Generated by PCPartPicker 2014-06-18 07:29 EDT-0400
It's cheaper, have a 240GB SSD, GTX 780 (or you can change to a R9 290x, and a bigger monitor
https://linustechtips.com/topic/168091-first-pc-build/#findComment-2236167
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($100.00 @ NCIX US)
Storage: PNY Optima 240GB 2.5" Solid State Drive  ($89.99 @ Newegg)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($509.99 @ Newegg)
Case: Corsair 760T Black ATX Full Tower Case  ($149.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($102.98 @ Newegg)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor  ($129.99 @ Best Buy)
Total: $1673.54
Generated by PCPartPicker 2014-06-18 07:32 EDT-0400
Plenty of room left for peripherals and any additions you want. It will perform the same in games as the build you posted for much less money.
https://linustechtips.com/topic/168091-first-pc-build/#findComment-2236182
