You will need to upload the last 3 .dmp files to some sort of file sharing website and then link it here for us to have a look at them for you. Not much can be told from the picture above.
quote me when you upload them so I can reply.
Just a quick question. Are you overclocked in any way? If so resort to bios defaults and see if you BSOD then.
Quack 🦆
https://linustechtips.com/topic/167672-recurring-bsod-plz-help/#findComment-2230632
Thanks a lot for your fast response by last 3 .dmp files do you mean the latest ones (towards the top of list)? And no I have not overclocked
Written on my Lenovo Z500 T - I5-3230M   Or
My pc :)
https://linustechtips.com/topic/167672-recurring-bsod-plz-help/#findComment-2230657
My pc :)
https://linustechtips.com/topic/167672-recurring-bsod-plz-help/#findComment-2230858
Yup I can read them and they are pointing towards a driver issue. Did you do a driver install/update lately?
Yeh i updated the intel integrated graphics recently as there was a bug that meant the screen brightness got stuck.
My pc :)
https://linustechtips.com/topic/167672-recurring-bsod-plz-help/#findComment-2231880
Double check to see if there is a new version out now. Could be caused by that driver.
I attached a  new picture to original post showing lenovo website on right and my drivers on left. There appears to be 2 drivers!?
Thx for your help on this issue
My pc :)
https://linustechtips.com/topic/167672-recurring-bsod-plz-help/#findComment-2238421
