Hi guys, I'm new here!
I recently finally got to building my second rig and I'm thinking about watercooling it. I have zero experience with watercooling so any feedback would be greatly appreciated.
My specs:
i7-4790
GTX 760 (planning to upgrade to 780 soon)
Corsair 750D case
Here are the components I am looking at:
EK High Performance 360 Rad
http://www.frozencpu.com/products/21322/ex-rad-646/EK_High_Performance_CoolStream_360_PE_Series_Liquid_Cooling_Radiator_EK-CoolStream_PE_360_Triple.html
EK DCP Pump
http://www.frozencpu.com/products/18968/ex-pmp-232/EK_DCP_22_12V_Water_Pump_EK-DCP_22_12V_DC_Pump.html
EK Supremacy Universal CPU Liquid Cooling Block - Acetal + Nickel
http://www.frozencpu.com/products/16253/ex-blc-1134/EK_Supremacy_Universal_CPU_Liquid_Cooling_Block_-_Acetal_Nickel_EK-Supremacy_-_Acetal_Nickel.html
EK 250 Reservoir
http://www.frozencpu.com/products/17509/ex-res-432/EK-MultiOption_RES_X3_250_-_Liquid_Cooling_Reservoir_6_Total_Ports.html
Tubing- any 3/8 ID x 1/2 OD tubing
Fittings x8
http://www.frozencpu.com/products/2296/ex-tub-38/Bitspower_G14_Thread_38_ID_x_12_OD_Compression_Fitting_-_Silver_BP-CPF-CC2.html
How does it look? I'm planning to upgrade my 760 to a 780 soon so I have to keep that in check for future watercooling.
My only concern right now is mounting the reservoir on my case as I have read elsewhere that it is difficult for this particular case.
Thanks guys!
https://linustechtips.com/topic/167320-first-build/
Hey Dispect,
welcome to the forum. At first I suggest you read the stickys in this subforum:
http://linustechtips.com/main/topic/1755-water-cooling-101-a-good-place-for-newbies-to-start/
http://linustechtips.com/main/topic/5435-watercooling-faq-some-basic-qa/
As for your parts:
Go for a D5 Pump, there are also beautiful combinations with Top Covers and Tube Reservoirs all in one like this one:
http://geizhals.at/eu/ek-water-blocks-ek-d5-vario-x-res-140-a1030220.html
Radiators and Fittings are up to you, there is not much difference.
Workstation: Intel Core i7-4790K@Corsair H100i; Gigabyte GA-Z87N-WIFI; 16GB Crucial Sport 1600Mhz; MSI GTX1080 Sea Hawk; Enthoo Evolv ITX; Samsung 840 Pro; Eizo Foris FS2333 / FG2421 | HTPC Bedroom: XBox One S | HTPC Livingroom: Intel NUC DN2820; Transcend 32GB SSD; 4GB Crucial Sport 1600Mhz running Openelec | Homeserver: Intel Core i3-4150@Prolimatech Samuel 17; MSI H97I AC; 16GB Crucial Sport 1600Mhz; Lian Li PC-Q35A noise dampened; 4x3TB WD Red Raid 5 on LSI 9260-4i running Server 2012 Essentials saved by a APC Back-UPS RS 550GI
https://linustechtips.com/topic/167320-first-build/#findComment-2226402
Please list your entire config so we can get a better idea of what you're working with.
Sorry about that, here it is:
Intel i7-4790
MSI Z97-G45
MSI GeForce GTX 760 2GB Twin Frozor
Corsair 750D
Corsair RM650 PSU
Hey Dispect,
As for your parts:
Gotcha! I'll switch out the pump for that one. Other than that, everything seems fine?
https://linustechtips.com/topic/167320-first-build/#findComment-2226455
Yeah, rest is fine. You don't need to buy such a high end CPU Block for your first build. Most of the time they dont differ that much. (a few °C in water temperature and pressure). EK Supremacy is really good, but you can also buy a EK Supreme block, they are almost as good but 20$ cheaper or a phobya LC-1 for instance to start with.
As I said, fittings are up to you (esthetics)
https://linustechtips.com/topic/167320-first-build/#findComment-2226557
If you are concerned with mounting a tube reservoir you could always go for a 5.25" bay res, many come with a d5 pump option as well. Also as Graveworm says, there is not a huge amount of difference between most cpu blocks so I would get whatever you like best in your budget.
Rest looks fine.
However you might want to check if you need any 90 degree fittings or other angles before ordering all standard compression fittings. Could sketch out your loop or just try visualise it in your case. Dont want to get all your parts and start out only to realise you cant make a bend without a particular fitting. Various different angle rotary fittings can make the install much easier, avoid kinks or putting excess pressure on a component which can result in leaks or other damage.
Hope that helps!
https://linustechtips.com/topic/167320-first-build/#findComment-2226906
My specs:
i7-4790
Corsair 750D case
EK DCP Pump
EK 250 Reservoir
Fittings x8
Thanks guys!
If i were you i would use this radiator for way better cooling than the 360mm radiator and i would really go with the Supremacy CPU block, as it cost less as was previously expressed.
You have not expressed any fans and tubes.
Some suggestions,
For the radiator i recommended, Choice 1  ------ For you radiator Choice 1
For your tubing check out Primochill they have a great variety.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/167320-first-build/#findComment-2227060
Only thing is that personally I would stay away from anything EK that was nickel plated.  They had a plating issue several years ago that burned many of us in the watercooling community and they did not handle it properly basically blaming the customers the entire time.  They eventually did offer us replacement blocks but by then most of us had gone and got other stuff.  I'd check out the Bitspower Summit if you want the acryllic look or the XSPC Raystorm.
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
https://linustechtips.com/topic/167320-first-build/#findComment-2227125
What do you guys think about XSPC kits? I did some looking and found that they have pretty affordable kits out there, specifically this one-
http://www.amazon.com/XSPC-Raystorm-Extreme-Universal-Dead-Water/dp/B00I8PJN3O/ref=sr_1_3?ie=UTF8&qid=1402964523&sr=8-3&keywords=xspc
https://linustechtips.com/topic/167320-first-build/#findComment-2227229
That is totally ok for a Beginner. Even though I was very angry at them for there Pump/Res combos (mine cracked, 2 Month old) but this set is totally ok.
https://linustechtips.com/topic/167320-first-build/#findComment-2228957
