Black Ice GT Stealth 140 Radiator - Black
$50.97 $50.97 ex-pmp-182
Alphacool DC-LT Ceramic 12V DC Pump + Plexi Top + Reservoir - Installed $82.97 $82.97 ex-blc-972
XSPC RayStorm High Performance Acetal CPU Liquid Cooling Block - AMD (Sockets AM2, AM2+, AM3, FM1)
So if I were to buy my own tubing at lowe's. Anything missing? Any concerns? For the moment it will be on an fm2 running at 3.5ghz, later it will be on a z97 lga1150 board. Will probably add more rad's then.
Dubs are better than subs
https://linustechtips.com/topic/167210-first-cooling-loop-build/
Is it? *trying not to stare at trippy avatar* Do you think that pump would be enough to push a 140 rad and a 360 rad?
https://linustechtips.com/topic/167210-first-cooling-loop-build/#findComment-2224999
