I'm building my PC next week and I have a question. How should I orient fans in the 450D? Currently I plan to have two intakes in the front, and all the other fans as exhaust, (radiator, bottom 120, rear 120) isn't there some positive and negative air pressure thing that effects dust?
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/167159-help/
for positive pressure you need more intake than exhaust
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/167159-help/#findComment-2224260
So I should also set my radiator fans to intake?
https://linustechtips.com/topic/167159-help/#findComment-2224270
is the rad on top?
https://linustechtips.com/topic/167159-help/#findComment-2224278
Also, I need an extra fan connector so will this fan splitter still let me control the individual fans?
https://linustechtips.com/topic/167159-help/#findComment-2224285
is the rad on top?
Yes
https://linustechtips.com/topic/167159-help/#findComment-2224293
http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026
(Tapatalk won't let me edit)
https://linustechtips.com/topic/167159-help/#findComment-2224298
No it won't the commands will be sent to both fans on the Y splitter. If you put two fans on a splitter be sure that you want them to be doing the same thing. As for the layout, x2 front intake x1 bottom intake, x2 rad exhaust and ignore the back.
https://linustechtips.com/topic/167159-help/#findComment-2224312
