NFS U2 HD problems!
Go to solution Solved by Deddie,
@ANUPLUCIFERGAMER
it says "only works on a cracked SPEED2.EXE", so that's probably your problem.
Hey guys! So, here's the problem. I had got this game NFS Underground 2 like a year back and it refused to work. Now, I just tried to install the game and it worked. I don't know how that happened though. Anyways, coming to the point, I came through this guide here about running the game in HD. So, I was happy, as others. I downloaded that thing (UniWS). And also the Texmod. I opened the UniWS, selected the game (NFS U2) but, I can't select the screen resolution for some reason. I tried reinstalling the game, reinstalling UniWS, but it still refuses to work! What should I do? I want to try this in HD! I then tried the "Find For me" option. I do get a pop-up message saying it found speed2.exe, but still I'm not able to change the resolution and patch it! What should U do? I went through youtube, and some people have the same problem as me. A guy said to reinstall UniWS, still not working! I've got this Pic here, you can check out!
http://imgur.com/GejDGey
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/167027-nfs-u2-hd-problems/
