I need help ... fast ...
Go to solution Solved by Stav Kats,
Then...emm... try disconnecting all your front i/o(case i/o) usb ports and reboot.
Hello everyone,
i have a big problem after i installed my pc into another case , nothing got damaged/scratched but when i turn my pc on it will show to bios logo but delete or enter or f12 works and it won't boot into windows and it doesn't post at all...
here are my full specs :
motherboard : 990fxa-ud3
cpu : fx 6100
ram : kingston valueram ddr3-1333
storage : corsair forge f40
               intel 330 series 60gb ssd
case : fractical desing arc define r2
gpu : gtx 550ti
power : sharkoon wpm 600wat
thanks for helping.
6600K  |  16GB HYPERX  |  GTX1070 FE  |  Z170X-UD3  |  AIR540
Respect the past, Embrace the future.
https://linustechtips.com/topic/16673-i-need-help-fast/
Sounds like your HDD/SSD that contains your OS is not connected or is in the wrong priority.
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/16673-i-need-help-fast/#findComment-190428
everything is well connected i've build allot of pc's before and the os is installed on the primary boot device (configured that while he was still working) it just stop's at the bios...
https://linustechtips.com/topic/16673-i-need-help-fast/#findComment-190431
https://linustechtips.com/topic/16673-i-need-help-fast/#findComment-190444
Can you see all the HDD on the bios? Are they booting in the correct order?
My sata data cable got just a little bit disconnected last week and i was like crazy figuring out what had happend, untill I realized that it was just a little bit off.
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
https://linustechtips.com/topic/16673-i-need-help-fast/#findComment-190473
i did it but the problem was in one of the ramsticks , it was placed in the correct slot but the stick was broken ....... R.I.P. 2gb of kingston valueram :'(
https://linustechtips.com/topic/16673-i-need-help-fast/#findComment-190826
