Hi guys I've recently been having a slight problem with one of my drives , I have a corsair 240gig ssd as a primary boot drive and over the past few days it's been playing up , it looks like it's just not being found when I boot into windows it just says boot from drive or insert installation disk , when I check the bios I can see my other hdd (main storage drive) but not the ssd but then I unplug the drive and reconnect it it boots fine , I check the corsair ssd software to see if the drive was failing but it's telling me the drive is in perfect health , I've tried changing to another port on the motherboard but received the same problem I'm going to try changing the cables to some others but beyond that it stumpt.
https://linustechtips.com/topic/166373-ssd-not-being-seen-help/
Maybe the lock on one of the connectors comes loose or something. Try new cables, if that doesn't work it could be the actual connector on the back of the drive, have a look at the lock see if it's worn down.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/166373-ssd-not-being-seen-help/#findComment-2214362
go to disk management and scroll to see your SSD
it will be like unallocated disk space
make a new volume
tada
Selling my parts of my 900D rig for a jacked up Ncase M1. PM me for offers if interested (will take some reasonable-low offers because I'm desperate).
Parts that I'm selling: 900D (1 slot cover broken for stealth DVD drive mod) | Asus Z87 Deluxe | Cooler Master 212 Evo | Corsair 4x2GB black ram @1600mhz | EVGA 1000G2 PSU (2 cables with missing heat shrink) | DVD drive | HP membrane keyboard | Ducky Shine 3 YOTS in blue switches (warranty sticker broken)
https://linustechtips.com/topic/166373-ssd-not-being-seen-help/#findComment-2214405
