Networking Questions
Solved by Blade of Grass,
A modem MOdulates and DEModulates the signal that you receive from the ISP.What is a modem and what does it do?
A router ROUTEs (directs) packets between the Internet and your home network.What is a router and what does it do?
A switch distributed packets in your local network (think of it as a very dumb router), it also enables you to expand the amount of ethernet ports.What is a switch and what does it do?
Cat is a shorthand for category, and the number that follows is the generation. Also, sometimes you have another letter that follows which denotes the "sub-generation" (Cat 6a, Cat 5e etc).What does CAT 4, CAT 5, CAT 6, etc. mean (cables)?
Cat 3 is the standard for telephone cabling too.
Anything above the Cat 5 standard is capable of gigabit ethernet, but the higher numbers are usually better (they improved it).
