Hey guys, so over where I live there are a lot of power problems. The power can just go out at any time (especially during the summer). My dad suggested buying an uninterrupable power supply. Can anyone recommend one for about 700-750 watts?
https://linustechtips.com/topic/165550-ups/
http://www.amazon.com/gp/product/B000OFXKFI?tag=kinjamod-20&ascsubtag=[postId|1465536280[asin|B000OFXKFI[authorId|5716553178370339807[referrer|www.google.com[type|mod-button
"The Cyberpower 1350 (specifically, the CP1350AVRLCD) is a mini-tower, 810 Watts/1350 VA UPS that features a helpful LCD display on the front to give you visual cues to the device's health, battery charge, load capacity, and if there are any current issues or faults on the line. It packs 8 outlets (4 battery+surge, 4 surge), and is well designed for home theater setups, computer workstations, and it's slim enough to fit behind or under a desk. It also features USB and Serial connectivity, protection for Ethernet, coax, and telephone lines. The included software will shut your devices down gracefully in case of an outage. Speaking of connected equipment, the 1350 also comes with a three year warranty, and a $500,000 connected equipment guarantee in case a power surge or other fault damages your gear on its watch.
Those of you who nominated the 1350 (and some other Cyberpower models) praised their longevity and their price-to-performance ratio. Some of you noted that Cyberpower's software leaves a lot to be desired, but overall the equipment is solid and those of you who use them love them. If you want one, they'll set you back $140 at Amazon."
"When in doubt, don't take your wallet out." - Dad
† TTCF Member †
https://linustechtips.com/topic/165550-ups/#findComment-2203369
Hey thanks, but I was looking for one that would go inside the case, like a normal PSU
https://linustechtips.com/topic/165550-ups/#findComment-2203512
Doesn't exist. You need A LOT of battery to provide 750W continously and stablely for even 15 minutes. Batteries are massive, so it's a limitation with physics than anything else
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
https://linustechtips.com/topic/165550-ups/#findComment-2203527
Yes I do, I want it just so I can have have like a minute to shut the computer down in the event of a blackout. I totally thought there were ones that went in the case.
Nope.
What's wrong with outside the case?
† TTCF Member †
https://linustechtips.com/topic/165550-ups/#findComment-2203828
Get APC. :P
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
https://linustechtips.com/topic/165550-ups/#findComment-2208457
