I bought an Gigabyte H87-D3H motherboard and core i7 4770k cpu with 16GB of G.Skill RipJaws-x 2X8 (ddr3 of course) without GPU (future GPU is Gigabyte GTX770 OC 4GB)
and my PC always crush and load (more like freezes then crush to blue-screen) please help me
thanks for the help everyone
https://linustechtips.com/topic/165428-help-please/
=(  you bought the wrong motherboard or wrong processor.  you wont be able to overclock.
Is it possible for you to return the products because we can build you a better rounded computer if all you are doing is gaming.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/165428-help-please/#findComment-2201743
what is your PSU?
corsair cx600m
no im not able to return the product
what is your cpu cooler
corsair hydro H100i
https://linustechtips.com/topic/165428-help-please/#findComment-2201774
Do you mean crash?
https://linustechtips.com/topic/165428-help-please/#findComment-2201789
Freeze where? On boot, BIOS or windows/OS? Could be faulty ram or SSD/HDD.
it freezes in windowns whene games are running and sometimes on windows
and i cheked the HDD that the game is installed on is my old HDD and it was working fine before i upgraded to this hardwere and i have my windows installed on an SSD with 60GB corsair
https://linustechtips.com/topic/165428-help-please/#findComment-2207175
can you suggest me some sort of memtesting programs
http://www.memtest86.com/ this is the one most used. I've last used it 4 years ago while troubleshooting some uni machines.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/165428-help-please/#findComment-2207768
can some help me i did memtest and it was fine my HDD that the games is installed is my old HDD and its working fine can it be my SSD or just the fact that the motherboard does not compatible with the CPU or its just other problem that some one thinking of please help me i`m on a budget so i don't have to money to spent as well as  that the PC parts in Israel is to much expensive
https://linustechtips.com/topic/165428-help-please/#findComment-2209797
What ports are the drives plugged into and are all drivers installed for the mobo?
https://linustechtips.com/topic/165428-help-please/#findComment-2209833
