Pretty sure the sites up (source: isitdownrightnow.com) but whenever I try to connect I get this:  http://gyazo.com/4f4390ef102901f4e0f5a91da491470c
Browser: Google Chrome. Also tried IE.
DNS: automatically get one. Also tried with Google Public. DNS flushed alot of times.
Chrome settings: Been running Default since I got chrome.
IE settings: Never used IE :P
Router reset: 2-3 times
OS: Windows 8.1
Don't know whats happening :( haven't been able to connect since yesterday. Last time I went on there was probably 10th June.
https://linustechtips.com/topic/165344-pcpartpicker-not-connecting/
Are you by chance having any issues with youtube? or issues with the google search page. I'm having both, but no issue connecting to pc part picker :\
Dubs are better than subs
no they're working fine. I do see some people having issues with it though.
Maaaan is using a proxy slow.... so pissing off. Stupid ISP.
If you're having slow googles @Trik'Stari, they might just be doing maintenance in your closest datacenter, I had that problem for 4 days straight and nothing helped but waiting :/
Main Rig: Cpu: Intel Core i7 4790k CPU Cooler: NH_d15 GPU: Gigabyte Radeon HD7970 Windforce III MOBO: Msi Z97 Gaming 5 RAM: HyperX Fury 1600 8gb white SSD: Samsung 840 evo 250gb PSU: Corsair CX750M Case: NZXT H630 white
PC peripherals: Monitor: Samsung Syncmaster T27B550 Keyboard: Logitech G105 Mouse: Logitech G700s Headphones: Logitech G430
