Hey cuties,
I need a hand with something, this my first time water cooling build. My 3rd build in total.
So essentially what I need help with is choosing ALL the bits. Compression fittings, res, pump, etc...
The specs are:
Intel i7 4770k
16GB (2X8GB) 1600MHz Vengeance Pro
250GB Samsung 2.5 Inch Evo
1TB WD Caviar Green 6Gb/s
NVidia GTX 770 Gigabyte 4GB
750 Watt Corsair CS750M 80 Plus Gold
Gigabyte S1150 MicroATX G1-SNIPER
Corsair Obsidian 350D
I have a $450 limit on the loop, and it has to be for the CPU and GPU.
Oh and it has to be bought on www.pccasegear.com
Thanks babes.
https://linustechtips.com/topic/165220-first-time-water-cooling/
Have you read any of the WC'ing Guides or tutorials available? I would think you'll be able to fit a couple of 360 Rads in that Case ;)
3930K - 4.85Ghz w EK Supremacy | RIVE w Photon 170 D5 Vario / Res Combo | 16GB 1866 Doms | Evga GTX 780Ti SC SLi w EK Full WB's| AX 1.2 kW | 900D - 1 x RX480 1 x EX360 & 1 x EX240 Rads w Noctua NF F & Corsair SP "Push" | W7 HP x64 | MK11: P25,113 http://www.3dmark.com/3dm11/7499603 | Firestrike: 19,576 http://www.3dmark.com/fs/1177627
https://linustechtips.com/topic/165220-first-time-water-cooling/#findComment-2198832
I would say you should buy whatever you think looks the nicest.
I like the compression fittings by Monsoon, mostly because they are the only brand that makes colorful fittings.
You should also get a D5 Vario Pump.
You could probably take a look at some of the complete watercooling kits and build off from those.
https://linustechtips.com/topic/165220-first-time-water-cooling/#findComment-2198935
Hmmm... I could put it up to $550? Not sure if that makes a difference...
Hardline or flexible?
If flexible, just go for something like this XSPC kit and expand on it as needed.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_45&products_id=27266
Also don't forget to quote or tag a user so they get a notification that you've replied and welcome to LTT :)
https://linustechtips.com/topic/165220-first-time-water-cooling/#findComment-2199305
