As many of you likely know when it comes to PSU calculations, and what i'll need to run my system, I suck.
So what i want to know is can i run the following on my Corsair HX1050 80+ Gold PSU?
3770K @ 5Ghz 1.344V
MSI Mpower
4 sticks of RAM
AMD Radeon 7990
ASUS 7970 DCUII
2 HDD's
1 SSD
8 Corsair SP120's
Fan controller
and two dvd drives?
I just don't want to blow up anything... Y'know?
Thanks guys.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/164844-need-some-help/
Could probably run 3 7970s overclocked balls to the walls without worrying about anything blowing up in the next 5 years..
I think you're all set, bro. That PSU is overkill.
Edit: Although, since you're using a high end HX power supply, it'll run mostly in silent mode regardless of what you're doing. Guess that's a plus.
https://linustechtips.com/topic/164844-need-some-help/#findComment-2193656
No problem at all. You'd be using about 900 to 950W of power at most, after overclocking.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/164844-need-some-help/#findComment-2193728
3770K @ 5Ghz 1.344V
MSI Mpower
4 sticks of RAM
AMD Radeon 7990
ASUS 7970 DCUII
2 HDD's
1 SSD
8 Corsair SP120's
Fan controller
and two dvd drives?
Thanks guys.
You have a 5GHz capable Ivy Bridge and you haven't visited the Cinebench overclocking thread? Go there now! So far I'm the only one who's managed 5GHz on Z77, I managed 5.1GHz on a H100i. :P
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/164844-need-some-help/#findComment-2193887
Got a picture of this monstrosity? :P
7990 is at the post office right now, I'll have the 7970 within a month or so.
Yeah, i'm way to busy right now for overclocking and playing around with benchmarks.
https://linustechtips.com/topic/164844-need-some-help/#findComment-2193973
