I am going to update my system soon, the whole system, but keeping the same HDD
Current system:
Cpu: a8-3870k
Ram: gskill 4gb
GPU: 7770
MOBO: asrock a75 extreme6
PSU Raidmax rx-530ss
Upgrade:
CPU: new i7-4790k (pre-ordered it)
Ram: Corsair Vengeance 8gb 2133
GPU: GTX 770
MOBO:MSI Z97-GD65 Gaming Intel Z97 Chipset
PSU: coolermaster 700i 700w
CPU cooler: corsair hydro h90
My question is, im keeping my same 7200rpm western digital HDD. Will i encounter any problems installing the new system and the harddrive?  will i have to do a fresh windows  install or something?
I also have another seagate2tb secondary drive, also running at 7200rpm
https://linustechtips.com/topic/164378-system-change-on-same-hard-drive/
You might have to since you are changing pretty much everything including the motherboard
I find it always best to do a fresh install when doing upgrades. Gives you an excuse to have a good clear out
Why not get a cheap SSD while you are at it :)
if you swap GPU only, no need. While changing motherboard you will encounter some old driver issues (those are usually hard to uninstall).
Making a clean installation of windows will give you smoother operation, aspecially if you were rocking your current setup for a yerar or two (most people even more).
So go for a clean install.
"Never trust anyone and rely on your instincts" - If you know who said it, you're awesome
thank you
thank you
