H100i clearance issues?
Solved by airdeano,
in R4 factory mounts you have this:
if clearance is an issue, you can utilize the mesh holes for secondary mounting:
if you still have clearance issues, then you'll have to drill new outboard mounting
holes for the radiator
1
toxic_worper ·
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning6
