I saw the nifty little power menu program that was pinned to the taskbar in Linus's unboxing of a Gigabyte laptop, so I thought I'd give a shot at making a little applet that lets you do the same thing.
Here's what it looks like:
Download it here (from my Dropbox): http://goo.gl/d56gz
Windows 8 specific notes:
Shut down button = hybrid shut down
Shift + shut down button = full shut down
Shift + restart = boot options menu
Changelog:
v1.1
-Added some credits for myself (F1 for help)
-Positions itself better now (X coordinate depends on where your cursor is, no longer bottom right)
v1.2
-Fixed Windows 8 hybrid shut down
-Added tooltips
v1.3
-Shut down and restart commands no longer flash command windows
https://linustechtips.com/topic/16419-power-menu-applet/
No I mean, have the program run at startup, and be on the notification are (next to the clock). SO that when someone wants to shutdown, they can click on it, and the menu will show.
Ah true. I'll work on a separate app for that, probably. It would look nice with the thinner borders too in Win8.1. :D
https://linustechtips.com/topic/16419-power-menu-applet/#findComment-219819
