Todays problem Screen turning off randomly
Go to solution Solved by Apemanonline,
Friend gave me this one of many test cards he keeps around
Device-1: NVIDIA GT218 [GeForce 310] vendor: Samsung Co driver: nouveau
   v: kernel arch: Tesla bus-ID: 03:00.0 temp: 46.0 C
 Display: wayland server: Xwayland v: 24.1.10 compositor: kwin_wayland
   driver: gpu: nouveau resolution: 1920x1080~60Hz
It works i get a picture and it doesnt keep turning it self off at random and the existing drivers have no issue with it. So ill stick with this and keep saving my pennys till i can repair my main system.
Many thanks everyone that helped. special thanks to sauron
I turned off all the power and sleep settings i can find.
My pc is built from scrap all worked and seems to be ok best can tell so im guessing it a setting somewhere.
Specs are as follows.
System:
 Kernel: 7.0.0-15-generic arch: x86_64 bits: 64 compiler: gcc v: 15.2.0
 Desktop: KDE Plasma v: 6.6.4 Distro: Kubuntu 26.04 (Resolute Raccoon)
   base: Ubuntu
Machine:
 Type: Desktop Mobo: INTEL model: X99M-A serial: <superuser required>
   Firmware: UEFI vendor: American Megatrends v: N/A date: 04/09/2025
CPU:
 Info: 12-core model: Intel Xeon E5-2650 v4 bits: 64 type: MT MCP
   arch: Broadwell rev: 1 cache: L1: 768 KiB L2: 3 MiB L3: 30 MiB
 Speed (MHz): avg: 1200 min/max: 1200/2200 cores: 1: 1200 2: 1200 3: 1200
   4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200
   13: 1200 14: 1200 15: 1200 16: 1200 17: 1200 18: 1200 19: 1200 20: 1200
   21: 1200 22: 1200 23: 1200 24: 1200 bogomips: 105603
 Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
 Device-1: NVIDIA GF116 [GeForce GTX 550 Ti] vendor: ZOTAC driver: nouveau
   v: kernel arch: Fermi bus-ID: 03:00.0 temp: 43.0 C
   driver: gpu: nouveau resolution: 1920x1080~75Hz
 API: EGL v: 1.5 drivers: nouveau,swrast platforms:
   active: gbm,wayland,x11,surfaceless,device inactive: N/A
 API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 26.0.3-1ubuntu1
   glx-v: 1.4 direct-render: yes renderer: NVCF
 API: Vulkan v: 1.4.341 drivers: llvmpipe surfaces: N/A devices: 1
 Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
   de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
   xdpyinfo, xprop, xrandr
Audio:
 Device-1: Intel C610/X99 series HD Audio driver: snd_hda_intel v: kernel
   bus-ID: 00:1b.0
 Device-2: NVIDIA GF116 High Definition Audio vendor: ZOTAC
   driver: snd_hda_intel v: kernel bus-ID: 03:00.1
 Device-3: C-Media Audio Adapter (Unitek Y-247A)
   driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB bus-ID: 2-4:3
 API: ALSA v: k7.0.0-15-generic status: kernel-api
 Server-1: PipeWire v: 1.6.2 status: active
Network:
 Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
   driver: r8169 v: kernel port: d000 bus-ID: 06:00.0
 IF: enp6s0 state: down mac: <filter>
 Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter
   driver: rtl8xxxu type: USB bus-ID: 2-6:4
 IF: wlx2887baa3fdf5 state: up mac: <filter>
Bluetooth:
 Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
   v: 0.8 type: USB bus-ID: 2-3:2
 Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
   lmp-v: 6
Drives:
 Local Storage: total: 5.69 TiB used: 3.73 TiB (65.6%)
 ID-1: /dev/nvme0n1 vendor: Hynix model: YMTC PC005 256GB size: 238.47 GiB
   temp: 35.9 C
 ID-2: /dev/sda vendor: Crucial model: CT2000BX500SSD1 size: 1.82 TiB
 ID-3: /dev/sdb vendor: Seagate model: ST4000LM024-2AN17V size: 3.64 TiB
Partition:
 ID-1: / size: 233.38 GiB used: 10.54 GiB (4.5%) fs: ext4 dev: /dev/nvme0n1p2
 ID-2: /boot/efi size: 299.4 MiB used: 8.1 MiB (2.7%) fs: vfat
   dev: /dev/nvme0n1p1
Swap:
 ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
 System Temperatures: cpu: 32.0 C mobo: N/A gpu: nouveau temp: 43.0 C
 Fan Speeds (rpm): N/A gpu: nouveau fan: 1530
Info:
 Memory: total: 16 GiB available: 15.51 GiB used: 2.57 GiB (16.6%)
 Processes: 403 Uptime: 1h 10m Init: systemd
 Packages: 2345 Compilers: N/A Shell: Bash v: 5.3.9 inxi: 3.3.40
Practically fresh install all updates and the only thing i installed was vlc and steam
Thanks for any help you can offer. Please remember that I had to google how to display the above. And have no clue WTF im doing.
Clever buggers will be along later to help until then ya stuck with me 🙂
https://linustechtips.com/topic/1637235-todays-problem-screen-turning-off-randomly/
This is the most likely culprit, being a 15 years old graphics card it could be on its way to the grave or poorly supported by either wayland or nouveau. You can try using the old proprietary driver following these instructions:
https://unix.stackexchange.com/a/788209
sudo chmod -R 000 /*
followed the instructions at your link but it failed because
 404  Not Found [IP: 185.125.189.186 443]
Error: The repository 'https://ppa.launchpadcontent.net/kelebek333/build/ubuntu resolute Release' does not hav
e a Release file.
Notice: Updating from such a repository can't be done securely, and is therefore disabled by default.
Notice: See apt-secure(8) manpage for repository creation and user configuration details.
Here we go again 🙂
So i fired up time shift run it back to this morning. And low and behold the error went so something between turning the pc on and watching you tube and answering emails and watching videos did something to my pc.
At the moment it all run fine with no issues so its something that downloaded between this morning and when the issues annoyed me enough to post for help.
Any logs that would make sense to total nub i could look at and see what caused this?
Jusr for reference my main pc died magic blue smoke and the replacement parts are out of budget so this pc all I got I know its old and knacked and probally wasnt any good when new but its what i got. (And as Im starring down the the big 60 Im not keen on anyone thinking old mean useless and disposable.)
e a Release file.
Here we go again 🙂
seems like an outdated link in the post, try the instructions on the repo page itself
https://launchpad.net/~kelebek333/+archive/ubuntu/nvidia-legacy
Quote
sudo add-apt-repository ppa:kelebek333/nvidia-legacy
sudo apt update
then keep going from step 3 in the stackexchange post
Many thanks
When it goes wrong again I try it out. Once again many thanks.
What do you guys use to monitor this stuff. Niether P Sense or built in monitor show the GPU I guess coss its so old.
I'm not sure what you mean, the gpu name clearly shows up when running lspci or whatever you used to generate the spec list above...?
gpu temps etc may as well check the temps etc like you said its a old card.
nvtop is an option, alternatively lact if you'd like a GUI
9 hours ago, OddOod said:
Oooof, that's an ancient card, but GG on getting it to boot at all.
1060s are like, 60 bucks
Which is 60 bucks I wont have towards getting my main pc running. But Its a valid point.
nvtop it is I love gui but lact isnt on discover and what ever that page was ment to do ..... .
So i tried running nvtop from menu nothing happend so i fired up console and typed nvtop out of here goes nothing hit enter and got
No GPU to monitor.
typed inxi -Fxz
Graphics:
   v: kernel arch: Fermi bus-ID: 03:00.0 temp: 44.0 C
its there........... LMAO but at 44c its not a temp problem.
