17 minutes ago, Shadow13 said:
I had iCUE Link, LConnect, Stream Deck Software, etc
Are you asking about running 5 or 30 apps at once? As good as your CPU+RAM combo is.
*using non-conversational, sketch-level language to gesture at structure and direction.
The GB8/12 Liberation Front
1 minute ago, Shadow13 said:
I am just wondering if it would do any bad on a AM5 build with those 3 constantly running
Would we continue to play hypotheticals, or do you have any particular CPU/RAM combo in mind?
10 minutes ago, Shadow13 said:
Oh my bad sorry, 64GB of RAM and  9700X/9800X3D
I'd say that you have nothing to worry about.
3 hours ago, Shadow13 said:
I was wondering how well a system would handle if I had iCUE Link, LConnect, Stream Deck Software, etc installed and running
That's what task manager is for. You can see how much resources a given program is using at any time. All three of these shouldn't do much besides use some RAM and a tiny bit of CPU.
Thanks, I asked since I wanted to know before I upgrade. a quick question how would they work on a 5800X and 32GB of ram? I am asking just to ask.
Exactly the same. Use some RAM and a tiny bit of CPU. Those are not performance intensive programs. They're intended to run in the background and be unobtrusive.
