So I just put in a new aio and trying to route the hoses down to keep any air at the top and avoid unnecessary “gurgling” type noise from my aio. With my gpu vertically mounted however the tubes are right behind my gpu and even touching but my gpu is a aio cooled one and shouldn’t get that hot anyways. So I’m just wondering if I should be concerned with that setup or if it’s perfectly fine. Thanks for any help in advance
https://linustechtips.com/topic/1636124-aio-hose-location/
look fine from the angles i see...
gpu is water cooled and a fan 🤔🤷‍♂️
Edited by thrasher_565
https://linustechtips.com/topic/1636124-aio-hose-location/#findComment-16890924
It’s the msi all in one gpu so it’s not a custom water block or anything. I think it’s how they have all their liquid cooled gpus. I also have the tilt adjust gpu mount and finally got to move right so the gpu is now tilted away from the hoses giving even more room so I think it’s fine fs now.
thanks for help though.
https://linustechtips.com/topic/1636124-aio-hose-location/#findComment-16890927
ya its stupid imo. its probably an expensive card and water cooling dose not need a fan and the card can be half the size...but w/e looks cheap imo
they probably reuse parts from air cooled card or something. the fans dose nothing...as i think there no pcb there or heatsink...so...
https://linustechtips.com/topic/1636124-aio-hose-location/#findComment-16890929
Probably something like that. You can see straight through the card and hoses when it’s not spinning so whatever it does it won’t hit much but adds something to the front of the card.
https://linustechtips.com/topic/1636124-aio-hose-location/#findComment-16890937
